Steering box issue
Henry/Kokomo
I'm in the process of building up an F-1 steering box to go in an AV8 roadster. I had the roller on the sector shaft replaced by a fellow "Barner" and that now works superbly. I got all new bearings and gaskets for the box as well as bushings and an oil seal for the sector shaft. I installed the steering shaft with the worm gear and everything feels fine. As soon as I install the rebuilt sector shaft, the steering shaft turns smoothly until it reaches the end of the sector's travel at which time it turns hard in the reverse direction. Am I doing something wrong or is the worm screwed up in some fashion? Any advice or prior experiences would be greatly appreciated.
Just wanted to be sure that you aren't calling the "end of the sectors travel" the midpoint of the steering (pointed straight ahead) as it is not supposed to have any slop at that position and if it is not properly adjusted it will get hard when you reach the center. Don't force it.
Charlie Stephens
the mounting pad needs to be moved closer to box or V8 wont fit. did you do this before rebuild. just wondering. Joe
Charlie - I probably didn't properly explain the symptoms. The steering box is cleaned and on the workbench.
I installed the steering shaft. It turns freely in both directions with no binding, wobble or any other detectable problem. Next, I installed the sector shaft at what I estimated the midpoint of travel to be -ie the wheels would be pointed straight ahead. After the sector shaft was installed, the steering shaft turned easily in either direction to the end of its travel. After reaching the end of travel - wheels cut sharply to the right or left - the steering shaft turns much harder in the opposite direction as in straightening the wheels up after making a sharp turn.
I have not proceeded further with the assembly as this scenario seemed wrong and I don't want to mess anything up.
Thanks for your input. Its much appreciated.
Joe - The steering box was modified so that location in the chassis shouldn't be an issue. Thanks for the "heads up". Can't have too many people checking your work.
Thanks
Have you adjusted the box for the centered position, ie no further detectable play of the sector in centered position? Any position off center allows a fair amount of play in the sector shaft. The box can be more easily adjusted when it is installed with steering components (front wheels) off the shop floor. The spindles are what set the stops of your system. The box on the bench has no stops. It just hits the end of the worm gear in each direction.
Adjusting it would be done first tensioning the roller bearings without sectorshaft engaging.
When you have enough pretension on the bearings you should have a sertain force turning the wheel 1.5lbs if i remember right.
Then after adding the sector shaft you should have 2.5lbs or something like that when its properly adjusted.
Don´t take my word for the numbers !!
John -
The box was not completely assembled. Thanks a million for the adjustment guide. Its a big help.
Regards,
