Yes, there is a gasket.
Do not put any gasket sealer on it, because you are anticipating that it will leak. The sector housing has to be able to slide and move to adjust it after assembly.
Instead of sealer, put a light coat of grease on both sides of the gasket. That will allow it to slide when required, and will help seal when you tighten the bolts.
