kooljunkguy
I have a 2 tooth steering assembly that my dad did all the rebuilt work too years ago and I just put it together. However, I can't torque all the housing nuts tight or the steering binds up and is VERY tight.
No I'm not tightening the adjustment nut, I've tried to loosen it up to see if it'll fix the issue but no luck. It functions and doesn't bind if all the housing nuts are slightly loose, and I've looked at the service bulletin page and followed the procedure but I can't get a really good adjustment on it and it leaks 600W like a sieve..
Any ideas?
This is my first time assembling a steering box so I'm not sure if there's anything I'm missing or should do
Any ideas?
