I think you can, the pinion shaft will come out thru the top, to get the old seal out.
Try not to disturb the steering shaft - four bolts on the end- the end play will be hard to re set if you damage the gaskets. You'll have to be very careful adjusting the screw for the pinion end play, real easy to over tighten it.
Karl
