Need to fix it so it doesn't leak. Usual culprit is the brass tube at the bottom that is crimped to the bottom plate - they come loose or wear through or break. There was just another thread on this subject. Otherwise, the 32-34's have no seal on the sector shaft (where it exits the housing and goes through the frame) just a cork, which does little or no good. We machine the housing and install a seal, but have to take it out/apart to do this.
Once leakproof, the filler cap says "heavy gear oil" so can use 600W which is nice and thick but will still migrate to where it is needed; others use 140W. I do not recommend STP, but it is still a "free country"???
