KULTULZ
... tell me if that much movement is normal
No, it is not normal. It most likely will have to be rebuilt (kit).
I just got off the phone with the owner of stangerssite.com. The '54 control valve is totally different from the ones he stocks parts for. He calls them 1st gen. The kits he has are for "3rd and 4th gen".
However, he gave me some pointers and ideas of what I could do with mine and it turns out that all my adjustments were counter productive. In addition after viewing my little video, he said the movement is normal. The lateral movement is actually the spool valve moving. That is how it works. I will once again take it apart and adjust it as he recommended, then move on to the steering gear box.
Please report back with his procedure and your results, especially the adjustment(s) if different from the 1954 WSM..
Now you can get the ball stud kit either vendor (who knows what quality) or NOS.
I’ve finished with my car in the ARC Shop and I’m so pleased with the results!
The paper shims at the box were essentially reduced in thickness which tightened up the steering slop.
I started out after measuring the shims with a 50% reduction…just a bit too much on the steering test.
The old shims..be aware that you get all of them out. One was so old it blended into the body of the box.
It is a bit of a pain to prep the steering column with the push back on the Tube and then removing the four bolts to access the shims. This has to be all reassembled to do the steering test.
Concours out of NV
Online catalog inventory will be correct probably less than half the time.They don't show the worm gear but the other parts are there.
