Steering Arm Bushings
dmaxweb
I've checked the major supplier catalogs and cannot find the bushings that go in the hole in wheel spindle forging for the steering arms.
Does someone have a part #?
If not, I'll give the suppliers a call tomorrow.
The "steering arms"??? You mean the A-3130 Spindle Arm (Right) and the A-3131 Spindle Arm (Left)?....There are NO bushings to put into the "wheel spindle", A-3105 Spindle Assembly, for these parts and that is why you did not see them in the catalogs!
Pluck
Pluck
You're right. I just went out and cleaned out the holes very well and they are just machined smooth. I didn't see any need for bushings in there but when I saw the grease fitting holes I thought I would ask just to make sure. Thanks
If you look at the shaft you see a groove in it. It is there so the grease can get around the spindle arm to the king pin.
