Tackle51 if you mean your trying to move the steering full left and full right while holding onto the tires, I think the front end is designed not the move easily so that when a pot hole or bad road in general is driven on the wheel is not jerked out of the drivers hand. When the front end is up in the air you should be able to move the front end lock to lock with one or two fingers in the spoke of the steering wheel. If you can't do that I would remove the drag link and then move the steering wheel it should very easily. Then you could also move the front end by holding the tires. If you want to improve steering ease you could replace the pittman arm with a shortened one and teflon steering bushings and new rubber booties on the tie rod ends, and both ends of the drag link. Also check the drag link sometimes they are on backwards. On later cars the grease fittings should face out to the curb on the drivers side. Good luck, A-Jay
