A aermotor Well-known member Jun 26, 2020 #1 Can the 4th adjustment be made with the steering box in the car if the column clamp is loose and maybe lifting the column with the horn rod released? (Two tooth box) John Last edited: Jun 26, 2020
O old31 Well-known member Jun 27, 2020 #3 Yes, but you do not have to lift or loosen the column or take apart the horn rod.
Patrick L. Well-known member Jun 27, 2020 #4 Yep. You'll need to bend a screwdriver to get at it. At least I did. Part of owning an old car is having to 'warp' or make tools to work.
Bob Bidonde Well-known member Jun 27, 2020 #5 You can buy one of these to make the sector axial play adjustment in the car. Attachments Offset Screw Driver For Sector Axial Play Adjustment.png 4.6 KB · Views: 19
Patrick L. Well-known member Jun 27, 2020 #6 I can remember when everyone said the box had to come out to check/set the 4th adjustment.
burner31 Well-known member Jun 27, 2020 #7 Patrick L. said: I can remember when everyone said the box had to come out to check/set the 4th adjustment. Click to expand... You are correct: But that was before a farmer said "Here boy, hold my beer and watch this"
Patrick L. Well-known member Jun 27, 2020 #8 burner31 said: You are correct: But that was before a farmer said "Here boy, hold my beer and watch this" Click to expand... I happen to like beer. Some folks said that couldn't be done after I mentioned it can. I still like beer and they are welcome to watch.
