Bob,My experience with the 2 tooth is that three adjustments can be done with the steering box bolted in place, the 4th only with the steering column out of the car.
It took several attempts with the box on the bench to get a very acceptable improvement in the slack.
I have also seen the pitman arm adjustment loose and causing a lot of slack.
Good time to check the lubrication level in the steering box.
Bob
TIP# 219: DON'T strive to get NO steering wheel slack. You need a little slack, to do your unconscious "hunting" as the road surface varies. With NO SLACK, it will dart on its' own. If you just BREATHE on the wheel, it will dart.
On Minerva, I had to go back & re-adjust it, to get a little steering wheel slack, then she drove GOOD. I recommend that if it has a little slack & drives good, LEAVE IT ALONE! (Well, that's what Chief taught me, BUT I won't use the words he used-+*%#%%$%^&)
Chiefs' Son
Thanks for Tip #219. I rebuilt my steering box following Les Andrews book and it was pretty simple. My only problem is with the adjustment process. I can get get real close to no play but as soon as I get no play it binds as I turn the shaft to the right. I've been messing with it for a couple of days now and just can't get it. It's so close but I wanted it to be perfect but maybe perfect is not the best thing.
If your gearbox has not been rebuilt and you try to get the play out of the steering when you drive straight down the road you will be to tight between the worm and sector when you turn right and left. Most of the wear has been done driving straight ahead and not when turning. My brother and I rebuilt his with new worm, bearings, sector etc. then made the adjustments according to Les Andrews and this made a very desirable steering when finished. This was the two tooth style for the 30-31 Model A
