Gary/IA
PROBLEM: When after a short stop for fuel or dining, the engine will start
at the touch of the starter but after going about half a block the
engine dies for lack of fuel. 1929 Special Coupe. 12Volt.
SITUATION: When engine is cold it starts and runs without a problem.
Always use NON alcohol gas and MMO added.
After engine dies, it will start up and run perfect until the
next pit stop and then a repeat of the same problem.
It acts exactly as if you forgot to turn on the gas.
Choking will make the engine catch a little but then dies.
ACTIONS: Checked for gas flow to carburator - Excellent flow
Gas tank clean and never sealed, pencil filter installed.
Three good carburetors tried - problem still exists.
Insulated steel gas line - no help.
Replaced steel gas line with rubber gas line - no help.
Installed heat shield around carb - no help.
Removed gas cap - no help.
Happens on cool days and hot days.
Never happens when engine is started cold.
Suggestions needed.
Suggestions needed.
