There is no ballast bypass like used on newer cars (at least on a '47) this may not indicate a ballast problem. I was quite surprised to see that the ballast resistor on my '47 was not bypassed when starting!It sounds like ballast resistor may be bad. Will the engine keep running if you keep the starter button engaged?
