Hi All,
My Model A started and ran two months ago. I got around to try starting it a few days ago and it didnt start.
I thought it was a spark issue. It had the older style distributor upper and lower plates, which I replaced with a newer style seeing as the lower plates wire was getting frayed and set the points to 0.020".
I unscrewed the dash to make sure it wasn't shorting on the gas tank.
I checked the coil with a timing light, and it worked fine. I got juice to both sides when the switch was on and points were open. With the switch on and the points closed I only got juice to the negative side.
I put the number 1 spark plug copper wire about a 1/16" away from the distributor cyl 1 terminal and cranked it over and saw a spark. The spark plugs have carbon on them but are not fouled. I replaced the dash and repeated this to and still got spark from the number 1 cylinder to the dist.
The rotor does sit a little uneven and the distributor body doesn't seem to be the best. The rotor cap clearance isn't an even 0.025 as it goes around on each one. Some it is 0.025 but one of them is approximately 0.010". I'd hate to just throw parts at this issue to try and fix it, especially when it ran not long ago.
I cant think of any more tests for failure to get spark.
I figured it was a fuel issue. I removed the line from the sediment bulb and truned the gas valve and gas shot out of the bulb. I reconnected the line to the bulb and unscrewed it from the carb. The gas shot out of the line that was connected to the carb, so the line is clear. I don't really know what it could be unless the carb was rebuilt poorly (I recently acquired the car 3 months ago).
Anyone have any insight? I've looked at countless youtube videos and searched on here for an answer, but maybe I am missing something?
Any way, Thanks so much for your time in advance.
Gordy
Gordy
