glmke
I have a 1950 ford with a 239 flathead, the problem i have is that I can start the car fine initialy and after some driving or say i have to get gas the car will not start and the battery acts like its dead. Had the same problem in my gerage after having to start car several times in a row while doing some maintenance. I checked the battery which is new and it had plenty of power.I also intalled new battery cables. the car is a + ground 6 volt system with a generator.Battery cables were made at a battery store using welding lead. If the car sits for awile then it will start,just seems to have trouble when turned off for a short period.
