A growler is an 110v electromagnet. The windings are wrapped around a soft iron core. It may or may not have an off on switch. Wire it up and check for shorts with a meter. If it has a switch, wire the hot wire through the switch. If it has leads to check for shorts in the armature on mine they are hot as long as the unit is plugged in.
To check, place the armature in the growler and plug in the unit. Hold a hack saw blade just above the armature and turn the armature. If the blade vibrates the windings are shot. If it passes that test you will want to next test the commutator for grounds. Place one of the test leads if the unit is equipped or lead from a meter on the iron core of the armature and run the the other lead around the commutator. If the growler is not equipped with test leads you can unplug it now. There should be no reading. If there is the commutator is grounded. If it passes those test next you need to check the shaft for straightness and more then likely turn the commutator. The mica between the sections does not have to be cut down on a starter.
Next check the field windings for shorts and look at the brush holders. If the starter needs new bushings and what not, be on checking the armature and field windings I will let someone else step in.
