When i push the starter rod nothing happens. I have good connections and 6V at the starter cable. If I take the cap off at the starter is there a brass connection that engages when you push the rod
that could be corded or something else?
Thanks
The voltage does npt drop when I push the rod so its not stuck.
Thanks
