The early starter you have will work with either ******, but the later 5/8" drive starter will only work with the single plate clutch.
The 5/8" is easier to find parts for and should be stronger since it's a larger diameter shaft, so you may want to switch starters anyway. If you are selling your multiplate package, then it should be worth more with the correct 1/2" starter included.
