My AV8 with '51 Merc in it. Been sitting for a couple weeks so I went to start and run it for a while. After the 2nd try to get it started, I let go of the key and it kept turning the engine over. Turned the switch off and still turning (not running). Had to pull a battery cable. Touched the cable to bat and still did the same. My first thought is the starter relay/solenoid is stuck. Pulled it and checked with a test light across the cable terminals and nothing. Has a universal ignition switch. This car has been run very little since built and everything in the electrical system was new. What else to check?
