Are the nuts, and washer rusty --is the cable one of those parts store ones with the steel ends crimped on??? (test with magnet)--the proper size wire??? --the power path goes from the wire to the terminal (the steel ends get rusty inside and make bad connections), then to the washer, then to the nut --which conducts it to the threads of the starter stud ---if the starter stud gets hot enough it can melt the solder attaching the windings to it --
