1965 Mustang
Does anyone sell a decent starter switch? I bought one from Mac's about a year ago. It is no longer any good. (Probably about 25-30 starts since replacing it) It is stuck in one position near the floor. (Does not go down or spring back up) I took it apart and noticed the cheap little rod of fiber/ plastic that is between the plunger and copper contact strip was kind of buggered up. On the bench I can kind of get the switch/plunger to move up and down, but installed the foot plunger just stays in one position near the floor and the starter of course does not operate. I adjusted the length of the plunger and lubed the firewall rubber bushing (where the rod goes through) but still nothing. The starter motor works fine when I apply 6 volts directly to the contact on the motor housing.
If anyone knows where I can get a good one please let me know.
Also is there supposed to be any kind of spring in the switch that might have broken and fallen out?
Thank you
Thank you
