Starter Switch?
GAR64
Ok, so I did a search and found threads about starter issues. Seems like my starter switch is bad. Starter sometimes remains spinning after car starts. Also, starter sometimes keeps cranking even if I release lever (I have one of those hand levers instead of foot button). I do have a shutoff, but when I turn back on, of course it starts cranking again. I can see that the switch rod does release when I release lever, so it guess it is an internal contact issue?Could it also be a problem with the starter itself??
Most likely a weak or burned contact spring. I use a good strong original spring contact, even if I need to restore the housing. File away any rough or burned areas.
