Hi Aok,
Humble opinion:
In comparing the very latest Vintage repro starter switches to an original starter switch:
A. The interior copper spring bands appear to have the same springy tension, thickness, & width.
B. The exterior steel bodies appear to be the same thickness & hardness, with a very correct profile in plan, section, & (4) elevations.
C. The battery cable connector through bolt has a new additional rectangular washer under the head of this non-ferrous bolt which appears to add better protection to the moving interior spring.
D. While both the originals & earlier Vintage repro starter switches had a hidden interior "cardboard fiber" insert at the lower interior end of the switch's rod tube, (which gets beat up over time), the very latest Vintage repro switches have what appears to be a better designed & seemingly more durable & more substantial looking Delrin or synthetic type of cylindrical device to replace this cardboard fiber item. (With everything else appearing as durable as originals, this one interior end of rod tube item appeared to be a hidden late model Vintage repro starter switch "upgrade").
E. It appears that "if" Vintage would consider a very minor re-design, & manufacture the rear top of starter switch's body with a very slight elliptical opening, the rear, upper end of the switch rod tube could move up & down slightly to accommodate different angles of the different starter rod angles coming out of the floor board area, thus not only producing better starter switches, but reducing numbers of new starter switches that are returned to vendors.
F. Having Model A owners rework the Vintage starter switch rod tube may sound easy; but it is not as easy as one may think, & it is very time consuming to get it "correct" where the starter switch rod tube does not stick & allows the starter to continue rotating.
G. One time after starting with a new Vintage starter switch, the starter continued to rotate "after" the engine was running & I could not hear the starter rotating.
H. Most responsible vendors & parts manufacturers would very much appreciate getting feedback like this -- it is non-productive & very costly for them to receive, unwrap, check, & re-shelve "returned" merchandise.
I. Let us continue to try to be compassionate & try to help "everybody" -- today, "all" of us have problems & need help with problems -- LOL.
J. In summary, with the exception of the "design" problem in paragraph E. above, appears Vintage repro starter switches would receive an A+ for design & durability.
