Jefscoupe
I bought the "stump puller" starter from Speedway for my 8BA.
I am using a Quick Time bellhousing and an aftermarket Fidanza (I'd never heard of them before but a good deal) aluminum flywheel with steel insert.
The issue is the ring gear on the flywheel is chamfered on the back side and my starter engages on the front. I know some of the early flatheads mounted the starter behind the flywheel but all the pics of 49-53 flatties (that I've seen) show it on the front of the flywheel.
The original starter on this engine was mounted on the front.
But it was all apart when I got it.
Does the bendix rest behind the flywheel and move forward when the starter is engaged on the stock starter?
Either way I need to chamfer the front teeth on the ring gear.
I just wanted to know how the original starter operated and if maybe Fidanza put the ring gear on backwards.
