Koates makes a good point regarding testing the end plate. You cannot have the brushes in place. If you do you will get continuity thru the coils giving a false indication. I have never seen an end plate that was faulty. If you think yours is, remove it completely from the starter, then check on a mid range ohms scale. I concur also, use a good battery, not a charger for testing. If you had the correct brushes in the correct holders, and your starter is still very week, your problem is elsewhere.
