starter plate
ripper57
kingsville
tx
(1) I need the starter plate that the starter mounts to. It bolts to the rear of the engine next to the pan. (1949-1953 flathead)
(2) I am thinking of using a 1932 grill on a 1935 ford two door. I also
am considering using 1935 pick-up front fenders as they cost less than
the car fenders. My only concercs are the running boards. Any inputs ??
ripper1957@ hotmail.com
Hi, ripper I have a few different ones cleaned and ready to be installed but need to know what bellhousing you are using.
I believe it's a cast iron from a dump truck. It's similar to the 49-50 mercury but the merc. is steel. Then trans. bolts on but it takes a early ford (1937 to 1948) or merc.
The starter plate bolts to the bell housing. Without the plate the bottom third of
the flywheel is visable.
Let me know what you got.
ripper
