glennsanders
Can a Ford car 8ba starter plate be used with ECM, truck bell housing ecm oil pan .They look the same except for the rib across the middle of the Ford one
Not sure exactly what you are asking but if you want to use the starter plate from a car with a full bell housing on a cast iron 8rt truck 1/2 bell housing or a Merc stamped steel 1/2 bell housing then the answer is no.Can a Ford car 8ba starter plate be used with ECM, truck bell housing ecm oil pan .They look the same except for the rib across the middle of the Ford one
First photo shows the truck plate and Merc plate. As I understand it either should work as long as the starter mounts parallel to the plate. Second picture, shinny plate on left is a car plate that mounts the starter on an angle and the black plate on the right is the one he needs. The truck plate needs the aluminum dust shield. Third picture.Let me start again.The man has a Mercury 49-53 using Ford truck bell housing with 39 3 sp trans Mercury rear sump oil pan.So witch starter plate would he use?
