Good Morning
Was having a problem cranking the engine (6 volt system). Would act as if there was a bind, hi compression, or a weak battery. Plugs out still wants to stop turning. Think the battery is ok so took the starter out to check. Removed the armature put it in a lathe and checked runout on the shaft. Have about 130+ thou at the end of the shaft.
So I think it is binding up as it turns. Is there any spec for max runout on these armature shafts?
I'm running 6 volt with a modern drive. If I use 12 volts with plugs out it turns quickly but still there seems to be noticeable binding as it rotates
Thanks for your help
RW
RW
