Starter dragging question
HCash
When I first engage the starter on my 31 coupe it turns over very slowly, like it's not getting enough power from the battery. After several very slow revolutions it seems to pick up speed. Is this normal with the Model A or do I have a problem? I have a 27 model T and it spins normally. Harv.
crank it with the key off... this takes the ignition system out of the equation... if it still cranks slow with the key off check the battery to frame connection / sand it off, all other battery connections, cables, ends, make sure you have the correct size cables, battery itself, starter would be last.
if it cranks normal speed with the key off check your igniton timing first.,,,
final note always start the car with the lever in the retard position...
Sometimes grease or oil on the commutator will cause this
also a bad connection ---crank the engine for 15 seconds with the ignition off and feel all the connections--both ground and power , any that are hot are bad connections or too thin of a wire
If the electrical connections are good, then it may be time for a starter rebuild. Look at the armature and field pole shoes for evidence of rubbing. The rear bushing (drive end) is the one that takes all the load and wears out first. I almost never have to replace the brush end bushing. Be sure the commutator is smooth, but DO NOT undercut the insulation between the bars. The ground brushes usually wear about twice as fast as the field brushes, which is fortunate because the field brushes need a good size soldering iron or soldering gun to replace them. The ground brushes are simply screwed in place.
A 6" piece of coat hanger with a loop on one end and a small 90* hook on the other end makes a handy tool to lift the brush spring to install the 4 brushes. Be sure the bushings get a dab of grease.
A 6" piece of coat hanger with a loop on one end and a small 90* hook on the other end makes a handy tool to lift the brush spring to install the 4 brushes...
One of these should work also. Couple of bucks at HF.
The title dragging starter reminded me of gpa trading a used up A for a better used A
Upon driving in the dealership, his battery fell down! Maybe we should all due more maintaince on our batteries, remove seats, remove floor boards, remove battery, clean ground, cables, holders, reinstall :-)
