starter cable 1926
Ashley
Is the starter cable on 1926 tudor routed down the frame and under the
hogdhead or over the frame near the firewall. Along the frame under the
hogshead does not appear to leave enough cable to reach the starter bolt.
Thanks
George
The starter motor to footswitch cable, (and the yellow battery wire from terminal block to footswitch) are placed within the large fiber conduit, which lays on top of the frame rail over the engine support arms of the crankcase.
Thanks for the information and pictures. I had removed the engine to repair the mag and needed help installing starter cable in the correct location.
Thanks again,
George
