starter button
I remember having a solenoid with a push button on the underside which was pretty handy. Not sure if they are still available.
You mean something like this ? If so, Harbor Freight, local parts store, Amazon, ebay
It wouldn't make a difference if it was 6V or 12V for testing. It just momentarily hooks one wire to another, or a battery to the part you want to test. I have a couple of them. It's just a momentary switch, with two wires, one to connect to power and the other to connect to whatever you're testing. like the one Paul showed us a photo of. 6V does require twice the amperage as 12V which would require larger wires but if you're just momentarily testing something a 12V test or should work fine. Except, it wouldn't work for the main power to a starter, it would go up in smoke along with your hand holding the tool, but for everything else it should be okay.
If you think you have a wiring or connection problem the best thing is to disconnect the battery and do a voltage drop test. This will show you where you have excessive resistance in a circuit. YouTube has several examples of how to perform the test. It's what I used as a mechanic for 30-years to find resistance issues in circuits. You just need a voltmeter. It will pinpoint where the resistance is in the circuit. It's a really neat test and will save you from replacing good parts.
yep. that's the one, or the twin, to the one i use all the time on my old 6v ford. one clip to the solenoid and one to one of the terminals on my battery.
Battery? Aren't you just grounding the terminal on the solenoid? Why would you connect to the battery?
My '52 F1's solenoid is activated by power from the starter button. I think most solenoids are grounded to activate, but not all of them.
Terry
