storyteller
I can only start my '39 flathead by pushing down on the solenoid button. Runs great. I checked the switch, it is OK. Ground wire from the switch to the solenoid checks OK. I grounded the small terminal on the solenoid directly to the engine, nothing happened. I have all new cables,etc. The solenoid is new also. (tried replacing that with another new one, no go.) I know the solenoid is nothing but a switch to send power to the starter or to feed the rest of the system with power. I have the hot wires on the right side of the solenoid as viewed from the front of the car and the starter cable hooked to the left side. One confusing thing is that the solenoids are embossed with BAT on the left side. Any ideas? By the way, this was the way it was wired before restoration.
