Mister Moose
Trouble is, a 12 v starter doesn't do the same job as a 6 v one. It spins the motor faster because it has more power, hence more than half the amps.
I don't follow this. Power and starter speed is not dependent on voltage, it's a function of design, the windings, and enough current at the battery to run it. Of course you could build a 6V starter to be more powerful.
The reason we build 12 volt systems, (and most modern aircraft at 24V, and tugboats at 32V) is to lower the current for the same power. Less resistive losses and as mentioned you can use smaller conductors. But it is not a power limitation.
