Started getting ads on FordBarn?
JayJay
It used to be that if you signed into FordBarn you wouldn't get ads. For the last several weeks that hasn't been the case with me, I get ads within the postings and also on the main screen. Anyone else having this issue?
Same here Ads after each post!!
When you google stuff and open a door to the barn while you still have an open window to it, you will get adds because it's not logged in for two windows. Also, you have to re-sign in every now and then and be sure to check the little box there in the sign in.
example?
1st step in most tech matters - Log out, log back in and see if issue continues.
Next step if it continues - log out, power off your device, power on your device, log back in. (Please note - I've found the 'Restart' option on most devices is generally not the same as actually powering off and powering on when trying to clear issues).
I am currently logged in and not experiencing ads. Whenever I've noticed ads is the same time I notice I can't see pics in the posts - because I'm not logged in.
Your mileage may vary.
I do not get ads, but I am not sure if it because I am logged in or because of the ad blockers that I have installed on Firefox.
Firefox browser, I get ads on FordBarn. When I use Safari on my iPad or Mac, no ads appear. ❓
Well they came back but went to my Adblocker and turned off refreshed and they All went away!!
Well, I'll be damned! Tried the same thing and it worked. Counterintuitive that turning the Ad Blocker off would remove the ads. But maybe it was conflicting with whatever ad blocker the FordBarn uses. I'll keep it that way for a while and see how it does.
BTW, using FireFox on a Mac, just updated to the latest OS (macOS Tahoe 26.2) this morning but it's been happening for several weeks now. Firefox automatically updates frequently. I use AdBlock Plus as my ad blocker. I don't have this problem on my iPad using Safari as the browser.
Gary WA, I was seeing the same thing you showed in Post #6.
And here I thought the days of software incompatibility glitches were long gone...
