Patrick
My A has been converted to 12v before I purchased it. The Engine has good compression and runs well.
The problem is that the cranking speed is very very fast. I installed a modern bendix,but I'm afraid that I will chew up the starter or the flywheel when it slams in as the started is engaged.
Not sure if the starter was converted to 12v or if this will make much of a difference with the crank speed. How can I tell ?
I do not want to convert it back to 6v since I have a 12 alternator,halogen headlights,etc,etc
How can I slow down the cranking speed ?????????
Thanks in advanve
Patrtic
Thanks in advanve
Patrtic
