Steve Rinaldo
I just got back from a test ride and the problem is gone. I did what you guys suggested:
1. Filed the carb and intake manifold Flat,
2Took the fuel bowl off and cleaned the screen flow was fine. The neoprene bowl gasket had rotted due to the ethanol gas.
3. reset the float level to 5/8.
4 cleaned all the jets and passages and found that one of the jets had a crack so I replaced it.
Thanks for all your help. Steve
