ampico-kid
Working through some "bugs" in my Town Sedan with the new Burtz engine. When the ignition is OFF, and I depress the clutch pedal, there is a very loud squeak or groan that seems to be coming from the clutch/pressure plate area. I've thoroughly greased the clutch pedal shaft and the associated linkages, and still the noise continues. I'm thinking something with the clutch pressure plate? Is there something that could be lubricated? Not sure, and don't want to do something that will kill the clutch plate. I also notice that the foot pressure needed to depress the clutch is way more than what's needed to depress the clutch in my Coupe. Can that tension be adjusted? Thanks.
