Sputter at high RPMs
The car isn't undrivable, it does very well at a moderate RPM range. Perhaps it will get better in time? I'll put some MMO in the gas to keep the valves lubricated and hopefully it will gradually get better. A very experienced club member keeps stressing to try a dofferent distributor just to see if that helps at all, which I will just to eliminate that also. But I do really feel it's that valve or valve springs. If it persists, I'll change the springs.
... Perhaps it will get better in time? I'll put some MMO in the gas to keep the valves lubricated and hopefully it will gradually get better.
Squirt some of that gunge thru the plug hole at the open valve to lube the stem. It'll be a bit smokey for a bit.
Without knowing the condition of your distributor and maybe the replacement, sounds like someone playing a guessing game and shooting off ideas. Unless the other distributor is brought back to factory, including where the upper plate rotates on the center with new cam/shaft/bushings and body to rotor air gap is set, why bother.
From what I read the valves, lifters, guides and springs were removed ...
Were all of the valves and lifters returned (in matched pairs) to their original positions?
If not that would explain the clearances being "All over the place".
From what I read the valves, lifters, guides and springs where removed ...
Everything was labeled and placed back exactly where they came out.
Glade you figured it out, way to go young man! I would have thought good or bad not intermittent.
Soon you will be an expert, and we will ask for your help :-)
The spring assembly that is attached to the movable points in the distributor can get weak and not able to close the points at high speed. It can also be in a position that it can short out temporarily at high speed.
