Take it to your local engineering shop. They should have a big press.Thanks much for all your input ! Will definitely help. This video is a great teaching visual ...for guys who like pictures, like me!
Do not have a hydraulic press and no torch. Will have to put the BFH back in storage, as you warn against that, eh. Yup, I can see the damage accumulate from hammer strikes. Hm, will have to buy a 25 ton press and a torch set up or?
The owner of a frame and axle shop in Seattle (40 years experience) spoke at our V8 club meeting a few years back. They are able to cold bend big truck axles for alignment purposes. They know how much pressure it takes to bend car and truck axles (have a chart), that is their business. He said he could tell when a Ford axle had been heated up red with acetylene torch/rosebud because it would yield at about half the pressure of an axle that had never had that done. That is why I suggested a propane heat source if heat was needed. I have never had to heat one with my press to get perches out.
Any decent machine shop would have the ability to push those out for you. However, it is your axle and you can use any method that makes sense to you.
