Spring Perch Nut
jj1928
I am installing new front spring perches. Is there a specific amount of torque for them or do you just get them as tight as you can ?
Thanks
As tight as you can. I use a 1/2 drive impact on them. There are many cars out there with loose perches. If you see space between the wishbone and the axle or any rust at the perches to axle there are loose.
No brain surgery here... Just get them tight
Larry
