I've been searching with Google and the board search engine, and I'm not finding an answer. Could somebody please tell me what's the spring-perch boss thickness on a T axle?
You will have to mill down the T axle 1/8" on the top and bottom to reduce it the 1/4" diffrence. Also the angle on the A wishbone ends is wrong, you need to cut them loose at the trans mount casting and correct the angle to basically straight and reweld it, unless your splitting them of course which you probably are. done this before, it's way better than the T wishbone.
