Spring Disassembly
Ben38
I'm trying to disassemble the spring off my 38 Standard. Is there a way to do it without cutting the rivets on the spring clips?
If I have to cut a rivet how do I get it re-riveted?
Thanks!
cut the rivet. roy nacewicz (734) 654-9450 makes a replacement "rivet", once installed you can`t tell it from an original. very easy to install also.
