What are you guys using for a "pad" between the top of the springs and crossmember? I remember someone on here said they made them out of some material.
So, I know why they were used on a Model-T but what is gained using them on a Model-A? When you compare the shape of the crossmember in the area the top spring touches and look at the way the spring is anchored, it can't move enough to squeak if it is correctly installed.
When I reassembled my springs I went by Les Andrews book that states "Cut an 8inch strip of body welt to be placed between the the spring and front cross member". And so I did!
i read somewhere years ago ,that the old guys used to use an old belt with the hole for buckle for the spring bolt. add some oil like others have said.....
