Conaway2
I’ve searched old threads and service bulletins for help with this, but it’s still not clear to me what the correct installation process is.
Springs are installed on the car. Covers are supplied by Snyders. I’m starting with the front spring. Felts are oil-soaked and I’ve applied extra grease on the top of the spring that will be covered.
I think the wider end of the cover goes toward the cross member, with the fastener on the bottom ?? Since the front spring on this car has 12 leaves on it, the cover barely wraps around the spring at the crossmember.
Any tips for getting the cover up into the cross member for the thicker end of the spring ?
Thanks,
Jim
Thanks,
Jim
