kimbercarrier
Hey fellas
I'm working on doing some blasting/sheet metal work on my 40 pickup cab. I need a recommendation for a spray can type of primer to use.
I bought a new box from Mack Hils, and I primed that with rustoleum epoxy primer. Now that I'm working on assembling the box I'm finding that primer is essentially peeling/flaking off. The last few times I've used rustoleum products, I've been less than impressed with the results.
Can you guys recommend a spray/rattle can type primer that can be used with a "professional" topcoat? As in I'd like to do the blasting/metal work as I can and apply primer in the repaired areas, and later apply a 2 part paint with a gun for a professional (but DIY) finish?
Brands/types please if you got them.
I've been reading about sem and seymour...
