Chances are when you remove the old top you will find lots of others things that need to be replaced. Water leaks in over the years and you will probably find rotted wood, stained fabric, rusted metal, etc. If the wood is rotted it will not hold the staples needed to fasten the fabric. Like anything else with these cars, take one thing apart and you will find 10 more underneath that need fixing. If you are planning to go through all the work to replace the top, why not do it all properly. As noted above, you are likely better off just buying a top kit from Classtique. They are cut slightly oversized so you still have to do a lot of trimming. I got the Stayfast top and it worked out great. They will probably just sell you the outer top if that's all you want, or even just the material.
