I recently had my wheels respoked (21" split rim). I am mounting the rims on the felloes with 4 lug nuts per wheel. Rims do not want to go up tight against the steel felloe. How tight should the lugs be against the felloe? Somewhere I read a 3/8" was acceptable. If I cross pattern tighten the lugs and take them to 50# torque is that sufficient? I recall that you can bend a wood spoked wheel by trying to force the matter.
Any thoughts?
Any thoughts?
