DANA BIZZELL
What is split sleeve rubbing are is it the key. Installed new two piece crankshaft pulley. Was careful to line up key with notch in two piece pulley. Once key in place pulled pulley on with ratchet nut, generator/water pump and crank pulley lined up good. Cranked up and loud rubbing sound and sleeve was hot. I did not run engine over thirty seconds. any suggestions.
Thanks
Dana
Thanks
Dana
