Baileigh Inc
I found out that I have a lug on my 28 sedan that is spinning. Cant get my wheel off. Won't tighten, won't loosen.
Any tips?
Any tips?
see if you can pull the wheel and brake drum together,tack weld stud to drum and remove nut, if not your going to have to split the lug nut with a chesil or a small disk grinder
Front wheel or rear wheel?
Remove the other 4 nuts and let the weight of the car rest on this one. The added pressure might hold the stud enough to remove the nut. Spray the threads with Kroil first.
