Tom is correct, as usual. The area you see a rough surface is from the machining when Ford made them. They machine at a faster rate in the taper area. The area that is smooth is where the Bearing race rides. This area must be in good shape. I had one of my spindles scored a little and slightly blue in color. This is from a Bearing just starting to lock up. When this happens the Race starts to spin on the spindle. It can overheat and turn the spindle blue, Not Good.
If the two areas where the Bearing Races are smooth your safe to use your spindles.
