spider hub caps
lilbro45
i had a question i recently found a pair of spider hub caps.. i have no use for them but i was just wondering what they are worth. they have some dings and scratches on them but all can be fixed. also the indented ones are 36 style or?
The repos go for over $600 per set,but that is new. Dings and scrapes cost $$ to fix soooo. Go figure. Yes the indented ones are 36 only. ken ct.
If I was in the market for spyder caps, I'd be looking for originals, as the repops seem to be made of tinfoil they're so fragile. How do you get them on and off without denting the new ones??
And about getting them off, I made a simple slide hammer for mine. No more going behind the wheel with a long screwdriver! :)
Saw a set of original at Hershey, 900.00 looked like new. Post photo.
Sample
1936 Ford Spyder stainless steel hubcaps 36 spider hub cap hubcap caps See original listing
1936-Ford-Spyder-stainless-steel-hubcaps-36-spider-hub-cap-hubcap-caps
Item Sold
Item condition:New other (see details)
Ended: Oct 30, 2013 23:40:25 PDT
Winning bid:US $510.00
[ 10 bids ]
Shipping: $15.46 Standard Shipping
Item location:Kirkland, Washington, United States
Seller:
kenfowles (1062 ) | Seller's other items
Spiders (order Araneae) are air-breathing arthropods that have eight legs.
Lawson,
Leave it to a lawyer to split hairs. Granted a spider is not an insect in the strictest sense of the word but for sure a wheel cover is neither a spider nor an insect.
My bad about the spelling of the hub caps.. yeah I can get pics. And I am interested in selling? Any more offers?
1936 Spyder Hub Caps - a History
These Accessory Hubcaps are correct as described in the heading for 1936 Fords. They are correct only for the 1936 Fords, as the V8 Symbol & Ring are recessed.
They do not fit any 1935 Ford, which had a Wire Wheel & the small Hubcap.
The exact same pattern (design) of V8 symbol with the Ring was used for the 1937 Fords, but these areas were "raised" for 1937 & not "recessed" as they were on the 1936 Hubcaps. (this is true for the regular issue Hubcaps also)
Then, for 1938, a totally redesigned Spyder Hubcap was offered as an accessory.
While Ford Motor Company redesigned the Regular Hubcaps on the 1939 Fords, (both the Standard & Deluxe are different) they never did update the Spyder Hubcap for 1939, but used over the "carry-over" 1938 Spyder Hubcaps on the 1939 Fords. That means that there are 3 different Spyder Hubcaps.
